350 Upgrades & Progress
garzas23
Brazoria County TX
AJ
Ok so after a long long long time of learning and trial and error thanks to this forum and everybody's help I finally have some progress updates and pics. I pulled my 350 awhile back with hopes of cleanin it up, painting it, replacing gaskets and dressing it up with some goodies for looks and performance. Still not finished lol
garzas23
Brazoria County TX
AJ
garzas23
Brazoria County TX
AJ
garzas23
Brazoria County TX
AJ
Ok having trouble trying to add multiple photos from my iphone so I'll just have to do it from my computer in the morning.. :sorry:
garzas23
Brazoria County TX
AJ
Before the prep work began
Hit it with the wire wheel down to bare metal and painted VHT gloss black
Then the the replacing began, first was the intake, timing cover, and oil pan.
put a double roller timing chain, edelbrock performer intake and painted the oil pan.
garzas23
Brazoria County TX
AJ
Ofcourse I also pulled the TH350 to give it a much needed degreasing and replace the front and rear seal, vacuum modulator, and clean the valve body real good. While the valve body was out I decided to put in a shift kit and replace all the gaskets ofcourse.
garzas23
Brazoria County TX
AJ
I still have to finish installing the water pump pulley, power steering, fan and a few other things. I am itching to fire it up!
marks86
Latham, NY
Mark
12v Cummins
looks awesome! I'm excited for you for the first start up. I love that feeling
350runner
tx
Ceasar
Looking good! Keep up the hard work.
garzas23
Brazoria County TX
AJ
Thanks! Its been a learning experience for sure..
firebane
Calgary, AB
Curtis
Don't forget to replace the bolt near the fuel pump on the front of the block to prevent any leaks.
Also that looks like a TH350C not a TH350. Can you post a picture if possible of the left side of the tranmission
garzas23
Brazoria County TX
AJ
Yes sir it is a th350C. Its my fault I never can get used to typing that C.. lol
I thought that bolt hole was just an accessary bolt hole I must have overlooked it, ill have to get it plugged. Thanks
firebane
Calgary, AB
Curtis
Negative. The top hole on some blocks is actually a pass through hole so you can stick a long 3/8 bolt through it to hold the fuel pump push rod when installing a new fuel pump.
This bolt gets missed on a lot of rebuilds and though it may not make a big mess it can lead to oil leakage from that hole.
garzas23
Brazoria County TX
AJ
Thanks again! I will get a bolt in it ASAP! Any extra info is appreciated.. I hope to give it the first start this weekend..
79K10
Sacramento,ca
Ryan
350/th350
looks great! good job!
jake26104
