350 Tbi running bad
Didn't read everything but just listened to the video. Sounds like a cam going flat. Sounds like the problem is with one cylinder for sure. Compression test and/or pulling plug wires one at a time to isolate cylinders would be where I'd go next.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
Hi, you mentioned that the back firing got slowly worse which makes me think it's a timing issue f.e. the distributor that turned slowly. When setting the timing, you did disconnect the tan wire and set the timing 0° right (see instructions on post 21)? Also, did you check if there are fault codes present ? Not all intermittent faults trigger the Check Engine Light.
Jonesie
Pa
Dave
Back fire thru the intake and exhaust, gradual loss of power: Locate and remove the O2 sensor, leave the hole open and fire it up. If after a couple of seconds it starts reving, and gains power ,the cat converter is bad and needs replaced along with the O2 sensor.
ratchetmaster
UT
Tim
I read through the posts. Have you replaced the distributor cap and rotor? If not, do it now. If yes, then continue forward. :D
ratchetmaster
UT
Tim
If you haven't yet replaced the fuel filter, then do it now before proceeding. if you have done it recently, then carry on. :D
ratchetmaster
UT
Tim
Have you checked all of your vacuum lines? IF not, then check them all.
ratchetmaster
UT
Tim
There has been some great advice on the thread.
Someone here suggested on starting with the simple things . . . I agree.
All the other info provided by the posters is great info.
Keep us posted on how it goes.
ratchetmaster
UT
Tim
One more observation. . . as mentioned the timing chain problem or a worn out cam are good possibilities with that many miles. Checking vacuum, egr, compression, fuel pressure, removing one plug wire at a time and seeing how it affects idle and drive-ability and seeing how it affects the engine are all good ideas.
ratchetmaster
UT
Tim
any update from the OP?
87silveradok20
Ohio
Levi
Silverado k20
I agree
You can see the exhaust light up at the end of the clip... although the flash is near the cat versus tailpipe.
You mean the muffler? No cats here
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Yeah, I realize no cats, but as a reference point. Where the cat would be... way up in the beginning. Not where the muffler is. ;P
87silveradok20
Ohio
Levi
Silverado k20
Here's an update to the this thread. I deleted the egr and attempted to reset the timing again and realized I hadn't unplugged the tan wire. I unplugged the wire and the truck won't run without it plugged in. Any idea what the problem could be?
With an otherwise healthy engine, it would mean the timing is too far retarded.
87silveradok20
Ohio
Levi
Silverado k20
Sorry If this is a dumb question but does that mean I should turn the distributor clock wise or counter clock wise. (Should he clockwise right?)
60Denais
