350 Build
Black Betty
ohio
Jake
K10 4x4
305ci
I have a 350 block, that I want to make high HP on a budget. All that I have is the block and I don't know what I need to get up to the heads..from there on I have experience... But I don't even know what parts are below the heads. I know the crank, cam and pistons. Is a crank the first step? Is there a kit I can buy that has EVERYTHING I need to get up to the heads?
350runner
tx
Ceasar
Knowing what you have for a budget is the first step
Black Betty
ohio
Jake
K10 4x4
305ci
I have the block and that's it.. I have a ticking/ knocking 305 that still has all its power so I'm sure I can use a few parts here and there from that
Skweegle89
Oklahoma
Lol budget, as in the amount of money you're willing to spend.
Black Betty
ohio
Jake
K10 4x4
305ci
Wow..I feel stupid lol.. okay:sorry:. I'd like to stay under 3000
Skweegle89
Oklahoma
What kind of HP are you looking for?
Black Betty
ohio
Jake
K10 4x4
305ci
I'd like 400 but at least 350
JRandle
Verden, OK
Jesse
Chevrolet Silverado
IMO.. Just LS swap it with that budget..
Skweegle89
Oklahoma
Or do this or something similar: http://www.summitracing.com/parts/nal-19210007/overview/make/chevrolet
Unless your dead set on building one or having one built. Do you have somebody you can trust to help you build it? I certainly wouldn't just walk into a shop and tell them you have $3k to drop on 400hp. You will likely get the ol' proverbial shaft.
Black Betty
ohio
Jake
K10 4x4
305ci
I really want to build it.. I was thinking 383 at first but I've heard that's more challenging
rich weyand
Bloomington Indiana
Rich
You can buy the base 350/260hp crate engine new, put a set of Dart heads and a 12-238-2 cam in it, and have a brand new engine with 400hp/430lbft, and a very nice broad torque curve. That engine ought to come in right around your budget, but there's extra money needed for headers, new intake manifold, new carb, etc.
Black Betty
ohio
Jake
K10 4x4
305ci
That doesn't sound too bad..iv got a edelbrock performer intake and 500cfm carb..both are probably to small?
Driver4r
Nebraska
Trevor
k10,c20
355
.030 over flat tops.
906/062 Vortec heads
.015 Felpro head shim
Alumium dual plane intake
knifeedge the crank
a nice came with some overlap.
you should be around 400-450 depending on how far down in the hole your pistons are in the block.
Get a rotating assembly off of ebay.
rich weyand
Bloomington Indiana
Rich
A 350 at 5000 rpm and volumetric efficiency of .90 is:
350 in^3 * 2500 per min * .9 * 1/(12 in/ft)^3 = 450 cfm
That's about the most you can pump through a naturally aspirated 350 at 5000 rpm. Another way to put it is you will run out of air through that carb at 5000-5500 rpm. The Dart heads will rev higher than that, but you won't notice any difference to 5000 rpm. If you want to get above that, you need to go to 600 cfm on the carb.
firebane
Calgary, AB
Curtis
Building a motor will always be WAYYYY more money than if you just get a crate motor.
Yes building a motor can be fun.. but realistically... think of how much you want to spend.
Chype1
