305 Carb adjustment
Joe b
tennessee
Joe
Hi, Can the carb mixture adjustment screw caps be removed ? stock carb.
Yes
Joe b
tennessee
Joe
Thanks, Howcan they be removed ?
ali_c20
Austria
Alexander
C20, K5
Get the carb off the engine and carefully drill or grind.
75gmck25
Northern Virginia
Bruce
There was a drill tool specially made for removing the screw caps. I think it was like a very small hole saw, so it removed the cap and casting but left the center threaded area for the mixture screws undamaged. Search some of the Quadrajet parts sites and it may still be available.
You can cut 2 slits with a hack saw blade on either side of the screw at the bottom and the cap will snap off.
Finkaire
Finkaire
California
Loren
Silverado c10
California, had mine done and redone for smog, argh!
Bumped the timing a little as well
Nm
Joe b
tennessee
Joe
Thanks all
MoGold
