Heatmizer
- Sep 18, 2025
- Hope BC
- Ian
- C10
I did search1st so sorry if I missed the answer.
Truck is 1977 2wd stepside (originally sold in Canada if that matters for safety items)
I want to replace my frayed seatbelts. Issue I'm having every single replacement I've seen online has the bolt hole for the retractor parallel to the belt. The oem belts have the retractor 90 degrees to the belt. The retractor bolts into the door frame above the door striker stop (metal post thingy) and sticks out into the cabin so the retractor is parallel to the upper anchor.
For all the replacements I've found there is no way to mount using the existing hole - I'd have to chop up the plastic b panel cover plus the belt would be twisted.
Hopefully attaching pic of oem retractor. This is all one piece, I can't separate the mount from the retractor. Also the hook at the top goes behind the sheet metal on inside of b pillar.
Any ideas wise people?
