2wd low hump floor on a 4wd?
Swims350
Logan WV
none
I've got a low hump 2wd 83 cab on my k10 frame it has the hump under the seat, but low hump up front will this work for it being 4wd? It has an np208 t-case, if not will 3 inch body lift do it? If not then of course I need the front high hump.
yevgenievich
Place
Name
Year
Model
Size
I have seen a 2" body lift referenced as a cure
Holl
Rich
suburban
I have a 84 2wd body (low hump) on 4wd suburban frame. PO used a 3"body lift to mount it up.
I'm grafting a high hump in the place of the low hump. Found a donor cab, cut out most of the floor and hump. The contours on the each floor matched up well. cut out the low hump and am welding the high hump in its place....
Swims350
Logan WV
none
I have 3 inch body lift uner it now and I also got a bolt in high hump to put in it
I've heard a 1in body lift will make a 2wd cab work. Not as much room around it, but it works. If you have 3in body now, then use it if you don't have a problem with body lifts.
Dennis Blom
