2 piece front drive shaft loose
beachsuburban
Delaware
J
v2500
So on the 2 piece front driveshaft where they come together there is a bunch of play and its making some noise. Also noticed a zerk fitting but I never greased it. Any solutions? Thanks!
xm20k
Girard, Ohio
Uh Ya grease the snot out of it and see what happens maybe You'll get lucky, and it won't be junk and stop making noise.
If they are built how I believe they are you may be buying a whole new drive shaft if it is shot.
Chevy 88
Canada
f7t6
GMC
I agree, grease the heck out of it and see how it goes. If that doesn't work, then you probably have to get a replacement. If you can separate the parts, then removing all the dirt and rust from the splines might be beneficial, so that it doesn't turn into a gritty paste that might further degrade the splines over time.
beachsuburban
Delaware
J
v2500
Yes the parts separate, I saw somewhere about a cork and dust cap as a fix, using this
Spicer D3A Dust Cap Kit​
from amazon
Would this work?
Chevy 88
Canada
f7t6
GMC
I'm not sure if a cork and dust cap would help, but I doubt it would hurt anything.
77Dmax
vt
Joe
Is the truck lifted? Once they are over extended they become loose due to a short engagement between the shafts.
That however may just be effed from a lack of grease. That is bone dry, and thats not good. That joint moves none stop as the axle hits bumps.
saltdog
US
K20 Suburban
take it apart, clean it up, grease it and add a new collar and yes-
Spicer D3A Dust Cap Kit is what you need​
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Take it to a driveshaft place and have it fixed. Make sure to tell them the truck is lifted. I am sure they will be able to tell from the damage how long to make it.
Just had both my driveshafts done. Rear - u-joints replaced and balanced. Front - Joints replaced and a new trunnion installed.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Another vote for a driveline shop, if it can’t be repaired they should be able to cut the slip joint off, replace it and rebalance it.
I’d gamble your double cardan joint at the other end is shot too unless the centering ball has been getting greased.
beachsuburban
Delaware
J
v2500
I am a little confused. What needs to be repaired besides the dust cap and cork? I don't mind taking it to the shop but that repair seems easy if it separates at the slip joint. Its wiggles a bunch so it should slide right off.
Memaloose
Bayard, New Mexico
Tony
If I were you, I'd remove the front shaft until it's repaired. I drove a '75 K/20 from OR to AZ and the front shaft came apart on the trip taking out the tranny pan in the middle of nowhere, a failed U joint. I had inspected and greased the whole drivetrain before I left but it was all OE. Anyway, to be safe that's what I'd do, you don't want a front driveshaft coming apart while driving on the highway.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I agree with you but the OPs info says it is a part time rig. 89 V2500.
Our old 77 Suburban (full time) had a catastrophic failure like you described while my sister was driving it and took out the transmission and came up through the floorboard. Truck was scrapped in AZ circa '94.:(
jw23655
