1989 chevy 350 aftermarket intake. Square bore. W.T.B
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I have a 1989 factory stock Fuel Injected engine I will convert to carb. I need a aftermarket aluminum intake
squarebore if anyone has one laying around they want to sell. Remember 89 had a different center bolt angle. Thanks.
The only difference is the angle on 4 bolt holes and there's enough meat on most if not all manifolds to egg the bolt holes with a dremel. or a drill bit and use an early manifold. Another option is run a Holley 2bbl on your TBI manifold.
Moderator
It takes a decent amount of hole slotting and you have to make tapered washers so the bolts can seat correctly. It's something I'm willing to do, but not everyone is.
Summit and Jegs sell the washers. I did one over 12 years ago,don't remember slotting being a big deal, didn't buy washers,honestly don't remember if I made some. I keep thinking I used rocker arm pivots as washers.
Moderator
You never stop amazing me. Rocker arm pivots is genius.
Moderator
^^^That's for the '96+ heads.
Or you could you know buy one that fits.
I thought he might have an early manifold underneath the squarebore carburetor he's planning on using. Sometimes I make things,or make things I have work to save the shipping time and/or money. If he's got a manifold he can use he can have this done before UPS gets there tomorrow.
xm20k
Girard, Ohio
Thanks for the correction. I forget there are 8 and 12 vertical bolt intakes. As well as half angled and half vertical. My Vortec blocks all had/have old school pattern heads.
Air gap style that fits everything but the 8 vertical bolt style.
Just the bushings for those interested.
Fat 454
Australia
C20 Suburban
LOL - tomorrow is a problem ! - here in the 3rd world we have 3 vehicles sitting around waiting on parts from overseas - may get here by the end of the month hopefully - and be correct fit ( oh yeah, I forgot .. you guys still make stuff .. ).
Don't take what you have too much for granted.
Some of us guys make stuff.
Nborden88
