1987 Chevy V10 steering wander
Yep just hook it and pull. If you can't watch them,then let them know you aren't concerned with measurements being green,you are fighting a problem and need to know what the real measured caster is,good or bad that way you know if you need to add wedge and how much. Do not put them in a cover their ass situation,put them in the mood to help you find your problem,for which you need an honest
real printout.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Yep just hook it and pull. If you can't watch them,then let them know you aren't concerned with measurements being green,you are fight in a problem and need to know what the real measured caster is,good or bad that way you know if you need to add wedge and how much. Do not put them in a cover their ass situation,put them in the mood to help you find your problem,for which you need an honest
real printout.
Don't even get me started with "It's in the green". I don't know how many times I have had to get involved with a case where the alignment is the issue but it is in the green. When I ask what are the angles, I get a blank stare and the tech repeats, "it is in the green". Most guys in the car business are truly lousy at their jobs.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
That's a pretty broad blanket statement and I call Bullsh!t. Sure there are some people in the business that are a little in the untrustworthy side of things, but to say most of us are, p!sses me off. You need to back off!!!!
It's like any other business,there are good techs,bad techs,and great techs( me for example) the bad ones make us all look bad. And we take so much abuse and are the scapegoat when things don't go as the car owner thinks they should. And then all their friends want to arm chair quarterback it and tell them they got ripped off,when none of them really knows what's going on. No one accuses the doctor of ripping them off, "Bob there's no way you have a broken arm,and just by "coincidence" the doctor found out you have a heart problem and diabetic. He's trying to scam you.These same people have no problem saying just replace my starter don't give me any B.S. about my battery cables. If I find loose balljoints doing an oil change,it's because I'm good at my job,not because I'm trying to scam someone.
As for alignments and in the green.If I'm aligning your car at a big box store,with a blanket price for the alignment, no matter how much work is involved,in the green is all you are going to get from me. If I'm at a mom and pop shop where I get paid for my actual time involved you are going to get a much better alignment. Especially the stores that sell the lifetime alignments They pay the tech full pay on the initial alignment,but pay about 1/3 for each subsequent alignment,all your getting, is in the green.
Nardulli
St Louis
C15
You mentioned that the steering box is new. Si the lash set properly? I set one up too tight once and the car was impossible to drive. Too loose was just as bad. I never came up with a spec - just tiny adjustments till it was right. Emphasis on 'tiny".
legopnuematic
Licensed Junk Dealer
MO
Spencer
This is from a 70s Unit repair manual. Should be the same for an 87 however. The 1987 unit repair manual should be available in the tech section of the forum.
First the thrust bearing needs to be adjusted, then the over center adjustment. Most people ignore the first step and make more problems for themselves.
Keith Seymore
Motor City
Keith Seymore
4.3L
Had the alignment done and it still feels the same, maybe a bit better, when I did the ball joints the knuckle preload did feel tight. Maybe this is the issue ? Should I loosen the preload sleeves on the upper ball joints?
Did you shim the caster up like I suggested?
It's something you can do at home, in the driveway, without affecting any other adjustments.
10 degrees is what we used in order to fix customer complaint vehicles that the dealerships couldn't fix.
K
legopnuematic
MO
Spencer
Based on what you describe, I’d look at the thrust bearing in the box first. Check/adjust that first, then check/adjust the over center adjustment.
Unfortunately new (or reman) doesn’t always mean right or better. Especially in the present day.
If everything else is tight, a steering stabilizer or damper should not be needed, in my opinion. Nor (once again, in my opinion) should it be seen as a magic fix for steering issues.
Dejure
Eastern Washington
Kelly
C15
Straight axles still use shims to adjust alignment.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
In my experience, I found that about 15-20% of techs are excellent at their jobs. The rest fall somewhere in the realm of mediocre to lousy. I have work in, managed, owned and provided technical support to service departments since the mid 80s. The diagnostic abilities of techs is getting worse. The job gets harder every year. It is not an easy profession.
As @Ricko1966 mentions about the pay for an alignment. Pay plans are a large factor in why diagnosis is lacking. Flat rate does not promote doing a thorough, by the book, type job. It encourages all the wrong things.
I was not calling techs untrustworthy. Those are a small percentage and are not the majority.
Fastduramax
Uranus
K10 Silverado
Well said Greg, let me add, I despise hacks but I must say in my current trade hacks have made me a **** ton of money... There is unfortunately a place for them at the customers expense having to pay twice or 3 times for the same issue, then I get the call correct the issue and charge a fair minimum knowing the customer got hosed by a "big box store" so called tech... Sorry this is an alignment thread, so my BF did alignments for a mom pop shop for 30 years, state of the art rack every 3 to 4 years give or take, owners retired and he hauled ass to Arizona now in this small area you have to travel 2 hours to a trustworthy shop, good luck getting an alignment at Monroe or Midas or Mavis, Oh that's right Midas went out of business huh
Johns C10 Hubcap
