1986 GMC LS SWAP. What size are both fittings in the steering gearbox? I need 6AN for both
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I called HOLLEY, CPP, and a few other companies with no luck. No one knew the port size for pressure and return fitting! I only need fitting sizes for gearbox.
:oops: Does any know the size of these 2? I need 6AN fittings Thanks.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
So I have one person telling me They are 11/16x18 and 5/8x18 Does this sound right?
I thought they were MM (METRIC) thats why Im insure.
yevgenievich
Place
Name
Year
Model
Size
Metric O ring style if for 86
yevgenievich
Place
Name
Year
Model
Size
M16-1.5
M18-1.5
But takes an oring to seal
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
M16-1.5
M18-1.5
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU
yevgenievich
Place
Name
Year
Model
Size
Worth checking to verify if current hoses used oring. Parts get swapped around
sirex
