1977 10 u bolt sizes for 2 inch lift springs
blackbird454
bristol tennessee
travis
350 small block
Hello I recently purchased a set of 2 inch lift springs and I did not receive u bolts does anyone know what sizes or maybe a kit that will work I have searched and not really found much thanks
Camar068
Air Force Supporting Member
10 yrs Air Force
measure it?
Chevy 88
Canada
f7t6
GMC
Buy ones that are longer than needed.
nvrenuf
Mobile, Al.
Any company that sells lift kits should be able to get a hardware only kit. 90% of all front lift springs have the same quantity of leaves ( = spring pack thickness) so it would seem that the ubolts would be the same for 2” as 12”.
blackbird454
bristol tennessee
travis
350 small block
I found a set from and all I could was universal kits over priced for u bolts in my opinion but oh well appreciate it
Everything you need to know,instructions for measuring and all. Probably don't need different ubolts than what you have, front lift springs are probably stock thickness,different arch. If you want to try to save your ubolts run a die down them all the way to the nuts,then wire brush the area behind the nuts.Reusing ubolts is not recommended but lots of people do it. Lots of things aren't recommended,but people still do them.
bajadiver
