1976 K10 Wiper Switch
vicnation
NC
Tristan
I've been trying to diagnose the wiper issue. I can get the wiper motor to work by grounding the right terminal at the motor connector. So, it looks like it may be the switch. I've removed it and found a lot of corrosion on the switch terminals. I cleaned them and reconnected it. Nothing. I sanded down the mounting points and reconnected and it still doesn't work. Assuming it's the switch, I have a dilemma.
I can buy a switch for a 73-74, a 78-83 and 84-87. However, I can't find a new one for a 76. None of the salvage yards within 50 miles have a 75, 76 or 77 truck. Can't find the part on ebay.
What are my options?
chengny
For model years 1975 - 77, I show the wiper switch as common to all C/K 1,2 & 3 - as well as the Blazer/Jimmy group. Note the only switch available was for "exc. intermittent w/s wiper system". That is true for 75/76. But it's wrong for 77 because intermittent wipers were made available for the first time in the 1977 model year.
Anyway, as you can see, the part number (1994172) for a non-pulse wiper switch is the same for years 75-77.
Some suppliers that have that part:
Dealer Contact Info:
Modern Chevrolet Company
WINSTON-SALEM, NC 27101
Chicago Auto Parts Bolingbrook Gm
Saint Ann, IL 60964
815-614-3122
Collectors Auto Oroville Gm
OROVILLE, WA 98844
800-414-4462
Craig Motors -Napa Gm
NAPA, CA 94559
800-224-8111
Or call Steve Phillips at Phillips Muscle Car - he shows 8 of them:
Thing is - they are really expensive. Every one I saw was like $85.
vicnation
NC
Tristan
Thank you for the information. I've already started reaching out to them. I'm within 75 miles from Modern Chevrolet so I might be able to pick it up.
Has anyone been successful using an aftermarket switch on one of these trucks? I see the round knob type with the wiper decal on the front and blade terminals coming out the back.
gmachinz
Harnessworx Inc
Iowa
Jabin
If you are willing to slightly trim out the opening for a larger GM switch I offer OEM pulse/delay conversion kits using a 1978-up motor for use on 73-77 trucks. I include color coded leads and a diagram detailing how to install my harness leads in your dash. My kits are $125 shipped and include the delay switch and wiring. Mods you need to do:
1.) Swap out your motor for a 1978-up style from any parts store.
2.) Enlarge your wiper switch opening about an 1/8 inch all around to fit the GM delay switch.
My kits feature a used but cleaned and tested delay switch. They are obsolete from GM so they are only available used and I have several kits as of right now. My kit replaces your dash switch and wiring as well as your existing firewall wiring to your old motor.
gmachinz
Harnessworx Inc
Iowa
Jabin
Stock 1977 motor....
gmachinz
Harnessworx Inc
Iowa
Jabin
....same 1977 truck with a 1978-up motor from O'Reillys w/my new firewall wiring....
gmachinz
Harnessworx Inc
Iowa
Jabin
....typical 1978-83 pulse/delay conversion kit for 73-77 trucks...
vicnation
NC
Tristan
Would I just need to replace the motor or would I need to replace the rest of the mechanism too?
Do you have a picture of the dash with the switch installed?
Thanks...
gmachinz
Harnessworx Inc
Iowa
Jabin
You only need to source (junkyard) the motor to linkage arm piece that bolts to the back of the motor itself-nothing else. I haven't got to the dash switch install just yet-this truck had manual Windows/locks and I'm in the process of converting this 77 GMC to factory power windows, locks and 1991 Suburban power mirrors. I'm building a dedicated all in one harness for it so I'll be getting to the wiper switch install soon enough....
Skillet_C10
