- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Now I see the confusion.
Your door plate mentions camper loading, but it’s not a camper special truck. Camper Special chassis package is option Z81, and it’s only for 3/4 ton (or bigger) trucks. IIRC my data plate lists GVWR of 8400, axle loading, and then a max camper weight of 2650 lbs. The wide band around the back and side of the cab also has camper emblems that look like a teepee, and the logo under it says Camper Special 8400 GVW.
For those who want more info - A factory camper special also has special chassis tie towns in several places. One on each front fender under the windshield, and one on each back cab corner with a bracket that extended through the front of the box. The system seemed to tie the box and the cab together with the camper. The camper connected to the cab brackets with some type of shock absorber.
Not all Camper Specials had those brackets. They were an additional option.
