14 bolt gear pattern opinion
Loco Hills
K-30
I need opinions,please.First gear set up.New bearings,gears,locker.
Backlash at .006
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Looks about right to me. Maybe a tic of pinion shim. Were you able to measure pinion depth, or just repeating what was already there?
Loco Hills
K-30
I went with the external shim that the original gear set/housing used.Not to sure how to measure pinion depth without the tool that goes in place of carrier bearings.Is there a way?
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
You'd have to check the gear manufacturer's instructions. Most aftermarket companies use a different system than GM. Either way, you need tools to do it. Since it looks like you're about 95% of the way there I'd just follow the instructions for the shimming to get the contact pattern right.
Loco Hills
K-30
That’s awesome.Thanks for your help.
Shak379
