Any tricks to getting your SB doors to close easier?
Edelbrock
Earth
Grumba
K5 Blazer
Gotta slam the doors on the K5 to get them to close. Its annoying.
I tried messing with the door seals, adjusting the striker, lubing everything, etc. No luck.
Thoughts?
Thoughts?
Are your hinge bushings worn out? Is the plastic sleeve on your door strikers?
Edelbrock
Earth
Grumba
K5 Blazer
Door bushings are OK. Plastic is gone, but the stikers are greased. Does the plastic help?
WFarm
Central Virginia
K5 Blazer
My drivers door has always been a PITA to close all the way. I hate slamming doors or anything else for that matter, but that’s what it took to close it all the way. Then I found the thread here about using 1/2” PEX to make new sleeves for the door catch. Some of my original sleeve was still there but not much.
Bought a stick of 1/2” PEX and made and installed a new sleeve. HUGE improvement!! Door shuts normally again!
Plus I have enough left over material to make replacement sleeves for the next 1268 years.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Plastic helps a lot - there was a thread not too long ago showing that PEX plumbing tubing works really well as a cheap replacement for the plastic sleeve on the striker.
Edelbrock
Earth
Grumba
K5 Blazer
Cool, thanks everyone for the info - I will try to fab us some plastic for the strikers. Anything else I should try?
Edelbrock
Earth
Grumba
K5 Blazer
As an Amazon Associate we earn from qualifying purchases.
Edelbrock
Earth
Grumba
K5 Blazer
Would rubber hose work? Probably needs to be plastic, no?
350 w/203
Rubber hose won't work. You can buy the new strikers if you want to spend the dough. PEX is cheaper.
hey mister
North Coast
Marty
PEX tubing cut to correct length...
Fixed both my doors.
Now they close with very little effort.
Carb'ed Vortec 350
Did you not use the search function? There is an entire OLD thread on the subject. Search is in the upper right, give it a try
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
The pex trick was one of the first things i learned about these old trucks. Happened on a short yt about it.
Oliver90_08
