Kick panel Speaker Mounts
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
Installed a pair of kick panel speakers and they sound like crap. I don't think it's the speakers, I think it's the panels and the tiny space for the speakers. I sound deadened the sheetmetal behind the panels. Thinking about taking the panels off and sound deadening the plastic panels. Cannot run any bass thru the kick panel speakers or else the plastic panel vibrates and the speakers sound like junk. I regret spending nearly $200 for these panels. Seeing if anyone has had any luck making them sound decent or any ideas on how to do that?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Can try "bolting" the speakers to the panels instead of screws. Maybe some sealer under the flange.
Shouldn't be running bass through components anyways. That's what subs are for. Kicker isn't terrible but isn't high quality anymore.
956moe
Moses
Gmc Sierra
:oops: oof i got some cheap plastic ones from ebay.... still haven't had a chance to install them. But for sure they will need sound deadning.
mxer147
Colorado
Jack
k20
They look much higher quality than the $35 I spent for some $2 cheap plastic covers which I plan to reshape, reinforce and paint. I don’t expect much from them other than mid range and not cutting up my doors. Speaker functionality is highly dependent on head unit and matching speakers with head unit impedance. An amp will also boost the performance significantly but will also increase $$. Impossible to have a low $$ symphony. I would glue a thin layer of hard material (HDF) to the backside rather than sound deadening.
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
My stereo does have an amp and I will install a sub but there is some bass that comes thru the speakers as well. These speakers were not that expensive but the system should sound better than it does. Not sure if high end speakers would sound better.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Typically the enclosure is what makes a speaker.
83Stepper
Massachusetts
Chad
Speaker quality does have an impact on audio quality, just sayin...
Do you have other speakers wired in for your fronts as well as the kick panels or just those? Also be sure to check the positive and negatives are wired correctly, you'd be shocked how many people do this thinking one side was hot when it was actually ground. I've got some cheap Pyramids in the dash and Scosche 6x9's in the rear of my 83 right now and it actually sounds pretty darned good. Adjusting levels of treble and bass as well as fader will help. If you want to get fancy you can add in some caps to cut out lows on the mids to aid in sound quality.
Beast496
Northern Nevada
Ron
GMC Sierra K3500
I saw this post while i was redoing my interior and used the speaker mounts from LMC. I didnt use the cheapo speakers that came with them and decided to go with some not so cheapo, but still cheap speakers (kicker 6.5) instead. I also sound deadened both the cab metal, as well as the underside of the panels. they sound very good.
Sad Sack
Omaha, NE
Goober
C15
Ah, the old music for my feet issue. Usually kick panel speakers will disappoint if you're wanting bass. Use bass blockers on them to cut the bass out, get a powered subwoofer for bass. I assume the dash speaker is centered and they make a new two-way style that fits directly in that location, then send your mids and highs to that and the kicks.
SquareRoot
These trucks suck for sound quality due mainly to limitations on speaker size/location. I have a pretty custom high end system and I still don't like it.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
A lot of good info already, one thing that hasn't been mentioned yet,
If the backside of the speaker is directly facing any hard surface the sound waves from the rear of the driver can bounce back towards the driver which can cause them to sound poor.
A thin layer of open cell foam glued to the surface behind the speaker can improve sound quality.
This may not be your problem just one more thing to look at. Adding passive in-line bass filters, reducing the bass setting in the head unit, or adjusting the crossover point in the amp should also help.
My kick panel speakers (kicker components on 100 watts) use the whole kick panel-rocker-A pillar void for an enclosure and they still don't sound as good or produce mid-bass as I feel they should.
SquareRoot
Are you talking about the void behind the OEM Sheetmetal? I have pondered that for a long time. Could you mount some 6.5's in there with foam baffles and perhaps a ring spacer if needed?
CalSgt
CA
Casey
It’s a little tricky, I originally cut the holes when I was in high school with the plasma cutter in welding shop. The hole is for 6.5” speakers.
There are two compartments back there, the A pillar structure and the cowl vent. I had to cut the inner sheet metal to clear the magnet.
In the bottom picture you can kinda see it, I ended up riveting some sheet metal in and smearing seam sealer on the edges during this build to separate the compartments. The A pillar compartment is connected to the rocker panel so there is some decent air space.
The new Kicker “KS” components fit fine without any extra modifications. My first set of RF components was too deep to fit, they bottomed out on the door hinge bolts so I used 1” Crutchfield spacers. The spacers caused the parking brake to make contact so I spaced it away from the kick panel with some washers.
I tried plastic baffles when I first did them but they rattled and sounded horrible. I ran those RF components forever without baffling just fine after that. I did add some open cell foam glued around the hinge bolts this time.
SquareRoot
Thanks for the reply and the pics. Appreciate it.
Turbo4whl
Downingtown, PA
Wayne
You have to bite the bullet and mount them in the doors. Now you have the enclosure. I know, I know, cut the doors....aah!
jbwhitford
