Remote Oil Filter
RanchWelder
Earth
Blazer
350ci
Here's the next update.
The headers installed are Hooker Cast Iron with 2-1/2" collector down-pipe.
Harris tuning suggested eBay Cat's.
So for $35 make offer each, the seller sold me converters, so I'm 50 state legal with the short exhaust.
They are 3" and will be necked down as slip-over for the 2-1/2" piping and at the collector they will weld direct.
I'm not sure if the OBD1 O2 sensor should be below the cat or not.
Let me know what you would recommend for best location "up stream" sensor using OBD1.
I'm considering the cats will be directly after the cast iron?
Ir down an inch or two max.
The three wire O2 mod has been done.
Usually you want them a bit further away than the 1wire O2 because it has a heater inside and doesn't foul up from soot if it's a little further away.
I'm listening if anyone has suggestions for best location if the new bung for three wire O2.
The remote oil filter plate is Moroso.
It wAs slightly used and very cheap.
The 45 degree fittings made it simple.
No 90's in the runs.
Made a bracket for under the brake master cylinder and used Summit Racing adaptor up top.
Here:
The Summit adaptor is drilled 1/4" NPT and reduced to the 1/8" NPT oil pressure sending line.
This allows me room for the extra long tractor filter later on, for added oil and extra cooling.
With the cat's so close, despite bot going long tube headers, it made sense to add the remote system to get the filter away from the exhaust.
The added benefit of moving the oil pressure sensor plumbing, is accurate pressure at the remote filter. Not at the original filter location or the top of the block.
Let me know where you guys would suggest welding the O2?
Edelbrock
Earth
Grumba
K5 Blazer
Uh... What?
Whats the question?
Uh... What?
Whats the question?
That's where I'm at too? I come to see a remote oil filter install and location. I like those things. The con is possible leaking hoses, mounted right shouldn't be a problem. The pros are, easy to change the filter so you're more apt to change oil when it's due and not put it off. The big gain IMO is, depending on where you locate the filter, it can work to cool your oil a bit too.
Hunter79764
Grand Prairie, TX
Suburban V20
You want the O2 ahead of the cats, usually as close to the engine as possible. Cats can be farther away, but the closer they are, the better they work.
xxxam
