Has anyone done this? Some ideas or tips could help.
fast_n_low86
Sturgeon County, Ab
Daniel
c1500
7.4L
So here's how it has turned out so far. I'm actually pretty impressed with it. Bumper tilts as well as the clip. Will be doing a bit more to it to make the front bumper tilt with my hood so I won't have to worry about tilting one then the other. Next step to that is using hydraulic struts to help lift the hood and bring it down smoothly. It's heavy but alot more manageable after cutting out the inner supports. YES IT IS ACTUALLY REALLY SOLID
heavymetal
canada
chev
c30
Looks like you been busy getting her done, good job so far. Before you go with hydraulic struts try checking out some electric actuators its quite heavy and you don't want that tilt front end coming down on you.It will eliminate using chains or cables as well when its at full tilt. Good thing about actuators you can use a remote with it and go as high as you want with it and not worry about it.
twitch1989
