Am I Crazy? Lincoln Drive Train Swap
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Hello All,
I stumbled upon this on FB. (<<Link)
It's right down the road from me. My plan is to remove it from the car then have the scrapper come get the car.
I'm thinking I could use the engine and mate it to a E4OD trans and use that in my truck.
Am I dumb or is this a viable swap?
Obvsiously it's a Ford but turn your Ford haters and let me know if fitting it all into my truck would be too difficult.
My Truck
1984 C20 3+3 with a 350 v8 and heavy duty turbo trans, 3 speed. 4.10 rear axle. 2wd.
The engine bay has a TON of empty space.
The Lincoln:
1978 Mark V with 460 v8. Per the ad starts up as is with a jump.
Thanks!
CountKrunk
SW VA
Count
v8 350
Per the Oracle that knows all yet nothing.
✅ ENGINE MOUNTING & FITMENT
  • Universal Big Block Ford Engine Mounts
      e.g., Trans-Dapt 4536 or Speedway Universal Ford BB Mounts
  • Fabrication material for frame-side brackets (if needed)
      e.g., 3/16" steel plate, gussets
  • Rear-sump oil pan kit (if needed)
      e.g., Canton 15-820 or truck-style Ford pan
  • Compatible oil pump and pickup
      e.g., Melling M-83 pump + rear-sump pickup
✅ TRANSMISSION SYSTEM (Choose One Option)
Option 1: Use Ford C6
  • Ford C6 Transmission (from 460 truck or van)
  • Custom or universal transmission crossmember
      e.g., G Force universal C6 mount
  • Driveshaft modification (shorten/lengthen as needed)
      + New U-joints if applicable
Option 2: Keep GM TH400
  • Adapter plate (Ford 460 to GM trans)
      e.g., JW Ultra Bell or Trans-Dapt
  • Custom flexplate (Ford to GM torque converter bolt pattern)
      e.g., TCI 529618
  • Converter spacing kit or adapter bolts
✅ EXHAUST
  • Ford 460 shorty or mid-length headers
      e.g., Hedman 88600
  • Exhaust system (fabricate or kit)
      e.g., 2.5” dual universal exhaust kit
  • Heat wrap or shielding (optional)
✅ IGNITION / WIRING
  • Duraspark II ignition module
  • Ford ignition coil
  • Ballast resistor (if required)
  • Ignition wiring: IGN hot, coil (+), coil (–), ground, distributor
  • Alternator (Ford or GM 3-wire)
  • Starter wiring (may require Ford remote solenoid setup)
✅ COOLING SYSTEM
  • Aluminum radiator (big block spec, check fit)
      e.g., Champion EC369 or Griffin 1-25201-X
  • Upper/lower radiator hoses (custom or universal flex hoses)
  • Electric fan kit (dual 12” recommended)
      e.g., Derale 16927
  • Thermostat fan controller
      e.g., Dakota Digital PAC-2750 or Derale 16749
✅ FUEL SYSTEM
  • Ford 460 mechanical fuel pump
  • Inline fuel filter
  • Fuel hose (rubber or steel braided with clamps)
✅ THROTTLE & KICKDOWN
  • Lokar throttle cable kit for carbureted Ford
  • Lokar kickdown cable for Ford C6 or TH400 TV cable adapter
  • Custom throttle bracket (if needed)
✅ GAUGES & SENSORS
  • GM-compatible oil pressure sender (1/8” NPT into block)
  • GM-compatible coolant temp sender (in head or intake)
  • Optional: aftermarket gauge kit (if redoing all gauges)
It would take some work,me personally I'd look for a 454 chevy. But if you want to do it,here are the things to think about,motor mounts are Completly different,I do think you could us Ford engine side mounts Ford engine mount biscuits and fab frame mounts to match. You will need to look at the oil pan configuration and if the sump is not in the right place,you need to see if any ford 460s have the sump in the right place,other wise you are making or modding an oil pan or making or modding the crossmember. You'll need to make or mod a transmission cross member and drive shaft. Also need to adapt Chevrolet engine Accessories to Ford engine,or wire and plumb ford accessories to a your truck. I'm sure I've forgotten things like you'll need to look and see if the ford exhaust manifolds will clear your frame,your steering shaft,and your evaporator box. Lots of things to look at,check and consider. If I was going Big block other than Chevy I'd be looking at other GM big blocks lots less fab work,and things to think about. And Olds Big Block is a bolt in.
CountKrunk
SW VA
Count
v8 350
Juice prob not worth the squeeze. Just very cheap to get the engine is what caught my eye.
Thanks @Ricko1966 .
Prior to this idea I've had my eyes long term on an LS swap.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
In the end you will almost certainly spend much more money and have significantly less hair on your head versus doing a BBC. Not to mention aftermarket support for BBCs is better than BBFs.
Turbo4whl
Downingtown, PA
Wayne
My 2 cents, you will see lots of Fords swapped with Chevy power. You will be hard pressed to find Chevy's running Ford power. Must be a reason. That said, you do you, go for it. Will be different!
Auburn, Washington
Dude, nobody wants a greasy 192hp when it left the factory big block.
No one even considers the above mentioned swap that requires major work and the resulting embarrassment and inability to open the hood around anyone but electricians and Ford guys!
I'll be honest, if I came across some dude that opened the hood on his Chevy pickup and revealed a smog era Ford 460 sitting there, they would have my respect. I'd also call them a crazy a$$ sumbitch, but they would have my respect, lol.
The Ford 460 has cubic inches, but it’s a Mom and Pop cruiser engine without much potential. It never came in a factory high performance version, and swapping in Cobrajet 429 parts would get expensive real quick.
fast 99
Spokane, Washington
Our company bought one F350 Ford with a 460. Comparing to a 454 absolutely horrible. No power, about 2 mpg less [7 vs 9] harder to pass emissions, more time consuming to repair. I really wanted an option other than GM at the time. Tired several cams and carbs, really no improvement over factory. Truck was a wrecker and heavy similar to towing a medium sized trailer. There are better options.
Rickf
Grafton NH
1974, 1954 & a 1937
Nathan's garage on utube puts a crown vic chassis under a C10. I would much rather see a C10 with the Chevy Caprice 9C1 package.
JBswth
Vallejo, California
James
C25
292 cubic inches
A 78 460 is a smogged turd that is probably about 200 hp. There are better candidates out there.
If he doesn't live in a smog-check state, he could rip off the smog junk and put a hotter cam, matching carb, and matching distributor for a 1969 - 70 engine in it. Then he would have, probably, about 330 horsepower. If he also replaced the heads or had them planed, 365 horsepower, and he would have something different and unique!
J. B.
Hotrod46
Louisiana
The biggest issue I see is the same issue that caused Chevy engines to be swapped into many pre-49 and early 50's Fords. That is the location of the oil pan sump. The 460 with it's front mounted distributor will most likely also have a front or maybe a mid-mounted oil sump. Most Fords had the engines placed forward of the front crossmember for this reason. There are exceptions though, like the rear sump pans of the early small block powered Bronco's.
You will most likely only have 2 options. Replace the oiling system with one that has a rear sump or torch out most of the crossmember on the Chevy. That will have to be replaced with something that clears the Ford pan since the front crossmember is a major point of strength on the Chevy frame. Might interfere with the steering, too.
In case you are wondering, the early Fords that got Chevy power were equipped with flat head Ford V8's. These had the oil sump in the rear, just like a Chevy. Since most folks back then didn't have a lot of fab equipment needed to make the early Ford overhead valve engines fit, the SBC was a natural. The Chevy was about the same size as a flat head and the weights were similar. Even a stock 265 SBC made way more power than a really (really, really) hot flat motor. There were even kits available that would allow swapping a Chevy into one pretty easy. These were available not long after the first SBC came available way back in the fifties through adds in the various Hot Rod type magazines. By the time the Fords got easier to swap in the late 60's, the Chevy in a Ford thing had become the way to go. Still is IMO, but then again, I'm just a Chevy guy.
twitch1989
