Rust coating for fill neck
GorillaHumper
Belmont nc
Bj
K10 short bed manual
My filler neck had a ton of rust in it. I scrubbed what I could out with a rust solvent and dryer vent brush on a drill. Is there a coating I can use on the inside to keep trash from going into my new tank?
fast 99
Spokane, Washington
There is a commercial zinc dipping company here that will do small jobs. Items are dipped in rust remover [acid] first then plated. Might try one local to you.
or Por 15?
Old Guy Bill
KY
Bill
Id think you could just replace it for the same cost…
I'd clean it and epoxy prime it.
good to note that any epoxy coating will need to be gasoline resistant and it will have to cure
Appliance epoxy from rustoleum says about a month, and i dont know if its gas resistant but just a random epoxy i read the can on
clee
