1987 Chevy V10 steering wander
Auburn, Washington
The caster can be adjusted as well but it is an extreme pain in the arse! You have the break the wheel end of the axle all the way down to the knuckle and install shims between the spindle and knuckle. I have replaced ball joints on 10 bolts and Dana 44's and have seen some of these shims in years past. I have not tried to source any of these shims but I believe that I have some stashed away somewhere. Maybe I'll find them in the kitchen junk drawer...
HS
Camber you mean?
Generally not needed to ever adjust on a straight axle.
Toe and caster, assuming components are all good/tight/not too tight, are the 2 primary causes/solutions to twitchy or wandering steering.
Generally 5deg or greater positive caster is what’s required or recommended.
Toe, never toe out. Zero toe or slight toe in for stable steering.
Strick
Dunn, NC
Harold
C20 Crew
Camber you mean?
Camber you mean?
@idahovette beat you to it. I should have misspelled AXLE to get @SquareRoot involved too!
Auburn, Washington
Oops my bad. Figured you knew, not being critical just clarifying for someone who may not know camber from caster or what they do to steering. Cheers!
Cdog_96
Aiken
Clay
The correct shims between the spindle and the knuckle for Camber. Is it loose or is it sticking from side to side and you have to correct constantly........To tight of Ball Joints can cause that.
Had the alignment done and it still feels the same, maybe a bit better, when I did the ball joints the knuckle preload did feel tight. Maybe this is the issue ? Should I loosen the preload sleeves on the upper ball joints?
RanchWelder
Earth
Blazer
350ci
Check the drag link is centered properly off the bump stops at both knuckles before you align.
Who knows if they will align the drag link before they try to align?
You would hope so.
Post up the before and afters of the alignment sheet.
Ahhh! Just read you replaced the steering box,if it's too tight it will cause a problem. Anyway here's procedure for checking the ball joints.
Cdog_96
Aiken
Clay
Can I do this with hub and rotor attached ? How do I adjust it if it is too tight?
Yes hub and rotor still attached,but steering links disconnected to isolate so the only resistance you get is in the steering knuckle you are checking. Look at step 5 for how to adjust. Sorry so late to reply,been a busy day. Still want to see before and after on alignment sheet.
Cdog_96
Aiken
Clay
Yes hub and rotor still attached,but steering links disconnected to isolate so the only resistance you get is in the steering knuckle you are checking. Look at step 5 for how to adjust. Sorry do late inbreply,been a busy day. Still want to see before and after on alignment sheet.
Didn't get one, I think all they did was set the toe
You need to go back and talk to them. If casters wrong you are chasing your tail. Ask them to put it back on the rack,you watch them,get a printout. If they touch the alignment heads or raise or lower the bumper after they do the caster sweep.( left right turn on setup ) they are cheating to get numbers that fall in spec.
Cdog_96
Aiken
Clay
I'll call them this week, gonna be tough to watch them with work schedule. As for using a fishing scale on ball joint preload, how exactly would I do that? Just hook the scale right onto the knuckle then pull?
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Any good alignment will include a print of before and after. If you went to a tire store you probably only got the toe set/checked.
Is your steering box centered? I have seen so called alignments done by removing the steering wheel and put back on so it looks straight.
Smik
