Hello new
Blazerlady
MI
Andrea
K5 Blazer
5.3 converted
Hello, I have a 1985 Chevy K5 blazer and a 1983 K20. The Blazer, bought in 2004 while I was in the Marines on leave. Did have a 305 which I did convert to a 5.3 out of a wrecked 2003 Chevy truck in late 2007. The 305 was smoking good and using oil. Was going do the swap after coming home from my 3rd tour in Iraq in early 2007 and did not happen . Shot at during combat which I was shot in my lower right leg 3 times which had to be amputated. Was in the dumps during my recovery which I got over waiting for my prosthetic leg. The K20,was a purchase in 2009 which someone put in a worn out 305 in place of the 350 and I converted it to a 12 valve Cummins diesel. It does go now.
Blazerlady
MI
Andrea
K5 Blazer
5.3 converted
Welcome young lady and thank you for all you have done for our wonderful country.
I also learned not to let my disability hold me back and got to the blazer once I got my prosthetic leg getting used to wearing it. The Cummins swap in the K20 was my idea after doing my research.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Welcome from VA. Thank you for your service. You got a Blazer and a diesel swapped K20, badass!
Blazerlady
MI
Andrea
K5 Blazer
5.3 converted
It is and I put in a 4L80E. Did fix the issues with the 12 valve Cummins before I put it in,one was take the timing cover off and fix the killer dowel pin problem. Pounded that pin back in and made a plate securing it with an inside timing cover bolt. I caught it in time, was starting to come out.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
WFO
Texas Panhandle
Welcome from the Texas Panhandle, Ma'am. And thank you for your service.
Strick
Dunn, NC
Harold
C20 Crew
Welcome from Central NC. Thank you for your service to our great nation & people. Thanks also for your love of Squares...folks & trucks.
HS
I been reading up on some of your posts. You certainly have had a rough life. You have strength that I cannot fathom. God bless you and welcome to the site.
:welcome:
Semper Fi sister... 88-94
Blazerlady
MI
Andrea
K5 Blazer
5.3 converted
:welcome:
It changed my life around, I was heading in the wrong direction in life hanging in the wrong crowd. Knew something had to change and enlisting in 1997 was a wise decision I made coming out as a better person
cutlerfab
