Dashboard "frame" removal 1984 GMC C1500
MadMash
Germany
Markus
Hello,
does anybody know how to remove the whole dashboard frame? I removed all screws, but it seems its somehow connected to the lower frame of the windshield...any ideas?
legopnuematic
Licensed Junk Dealer
MO
Spencer
The dashes are spot welded to and are one layer of metal at the windshield flange. To remove the dash the spot welds must be drilled/cut.
MadMash
Germany
Markus
Aaarghh...thanks for your answer.I was afraid of that. So I have to take out the window seal and the windshield. Oh dear.
Out of curiosity, why are you removing the dash frame?
I ask because usually when someone is removing it, they already have a replacement and know that it is spot welded in. If you aren't replacing it, you are likely creating more work for yourself than you need to.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
I’ve got a hacked one I plan to replace. I plan to cut from the defroster duct to speaker opening to the side and leave the forward piece in and butt weld
MadMash
Germany
Markus
I hope I don't get into trouble here, but I don't like the interior anymore and I want to build a completely new custom dashboard. But I think vr1967's idea is probably the simplest.
It ain't gonna bother anyone I don't think. A stock dash can always be put back in.
Kurt at Diy4x4 offered a custom, aluminum dash, that may make your life easier. Now with that said, he has recently shifted markets to the race car crowd, but I believe he does still take orders for some of the items, that dash may be one of them.
Southzj
