700R4
Donald
Loris SC.
Don
GMC 1500
I bought a used 700R4 , I am tring to find out what it came out of . It has 1WAM164A stamped on the ID flat spot has a 2WD and a K case and a Corvette c4 tail housing . Any ideas would be greatly apreciated .
NickTransmissions
Las Vegas
Nick
Interesting...The case itself is a 1991 model year case, WAM indicates model however I don't know what specific model...
What are you trying to install this 700R4 into? A Corvette or a Squarebody truck?
Here's a break out of the casting numbers and their respective meanings:
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
A "K" case has a thicker flange that the dust shield bolts on to. I think That k case was a
HD truck trans. Good starter trans for a beefy build.
Jgonick
West Texas
Joel
1WAM164A
1991 4.3 L "G" Van wiring type 18 - "164" (numerical day of year made) on A-shift
theyoho
Kansas
I also am having a hard time finding a chart with the 700R4 codes. My transmission code is: 4IK280D, I know everything but the IK code. Can anyone tell me what the IK code is please? It is in my 1987 R10 that I had for years thinking it was the original tranny, until I went to upgrade it. After trying to install an incorrect tc I discovered it was most certainly not the original tranny. Thank you.
Jgonick
West Texas
Joel
Could it be 4TK280D ?? 1984 - 5.0L & 5.7L "K"-TRUCK (Fed & Alt) wiring type 1
I don't see IK anywhere..
NickTransmissions
Las Vegas
Nick
What was wrong with the converter that made it incorrect for the transmission? Was it set up for a 27-spline input shaft instead of a 30-spline?
If so, your 700R4 is an early 1984 unit. Late '84 saw the intro of the 30-spline input shaft, "152" drum casting, large-dia stator shaft and new torque converter designed to mate with these other new parts. Both of these transmissions are "non-aux valve body" units
You should have an "aux valve body" 700R4 with a second design main valve body and spacer plate as well as an "097" forward drum and 29-element forward sprag...
theyoho
Kansas
Jgonick, It is possible that the code is 41K280D but from what I read the second and third characters are letters not Numbers. If you zoom in, it kinda looks like it could be a 4 but it is different than the first four. Nick Transmissions, I had the transmission rebuilt by my local tranny shop about 9 years ago and he didn't say anything about it being an older tranny. Recently the truck started demonstrating signs of a bad torque converter so I replaced it. I, of course, ordered one for a 30 spline. Went to install it and upon trying to get the three clunks immediately new something wasn't right. Long story short I installed a new 27 spline, after running the code, and it is working good now. I am just wanting to find out more about this tranny. I am the type of guy that likes to know as much about my vehicles as possible. Let me know what you think the code is. Thank you guys for the help.
Jgonick
West Texas
Joel
4MK ?? 1984 5.0L & 5.7L "C"-TRUCK/"G"-VANS (Fed & Alt) wiring type 1
Attached is the list I have from thm-700-r4-update-handbook-atsg-automatic-transmission-service-group. (page 101)
LINK- 700-r4-update-handbook.pdf
PartsMan79
Enid Oklahoma
Josh
c1500
I would wager that your transmission has been to a reman shop or two.
NickTransmissions
Las Vegas
Nick
It's an early 1984 unit if it came with a forward drum w/a 27-spline input shaft. I never pay attn to the rest of the characters; for me they're meaningless. The first character (an integer) combined with the presence or absence of a large, upside down "U" shaped cast crease on pass side of the case are the only two things I look at to determine what sort of 700R4 I'm looking at, assuming it has the V8 bell housing bolt pattern.
Knightewulf
