Driveshaft length for stock k15 short bed
abanker
Boston
Aaron
GMC k15
I have a 77 K15 shortbed with an th350/np203, dana 44 front and gm 12 bolt rear. Im looking for specs on the driveshafts front and rear. Multiple lengths and sizes available on rock auto. I am ordering parts right now with the truck not on hand. Can anyone tell me what size driveshafts I need front and rear or part numbers for them? Any help would be appreciated! Just looking for stock replacements
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Just wait until you have it… a tape measure doesn’t lie.
Also I’ll add a local driveline shop will most likely serve you better than ordering replacements on the interwebs.
Does it not have any driveshafts? Often times a great savings can be had by re-using the slip yoke and tube yoke. Also for the front shaft the double cardan joint may be salvageable.
Rickf
Grafton NH
1974, 1954 & a 1937
I've used South Shore Bearing in Quincy for driveshafts.
abanker
Boston
Aaron
GMC k15
it has driveshafts currently, they are pretty thrashed and the old splined slip joints have a lot of slop
abanker
Boston
Aaron
GMC k15
Ill have to check them out. They are pretty easy for me to get to. I imagine I can probably bring them my old driveshafts and they can replicate them?
630erik1
