‘83 K5- seeking design and material ideas on bed side panels and compartments for storage
BlazerBill
Billy
Chevy K5 Blazer
‘83 K5 restoration: I’d like to hear what you all have done with the bed-sides as far as what rugged hard material (wood, metal, other) did you use and if and how you incorporated any compartments (hidden, hatches, locks, molle) inside the panels for storage of things (guns, tools, speakers, amp) while also considering what what may be mounting on the outside of the panels such as tie down rings, recovery gear, etc and the best place to mount a spare wheel. Would love to hear your ideas! On another note, I found this dimension sheet online for the side panels but letting you know it is not accurate for 2nd gen Blazers, perhaps for 1st Blazers so I made my own template for my ‘83 K5 and can provide dimensions and construction methods, if wanted.
CountKrunk
ATL
Count
C20 Custom Deluxe 3+3
v8 350
How wide of a space is that? Looks like 2-3", juice may not be worth the squeeze
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
I used wood paneling in my burb. It was flexible but rigid enough. Didn't make any pockets or shelf though. Just covered it with padding and wrapped it in some apolstry fabric that was close.
CountKrunk
ATL
Count
v8 350
Very nice @Jawzjeep
aesthetically pleasing, but perhaps not worthwhile from a storage viewpoint.
Has anyone else stuffed something into that space? I think, maybe some guns or perhaps fishing rods might fit.
Jawzjeep
Washington
Joshua
Suburban
@CountKrunk Blazerbill asked about materials. And if storage was created. K5s and burbs are different in the back panel area. K5 shows the inside of the bedsides when you pull the side covers off, burb don't so there's no open space.
@BlazerBill we took a plastic bed cover and cut it down to fit into a blazer. Had to cut a little bit of the back off and the part that would normally go up against the cab side of the bed. We were able to drill holes and attach it on the sides where they side panels bolt on. Would be really easy to build small little Cubbies that open up in that material too. We thought about using the front of a glove box from a Jeep.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
Those bare inner bedsides are begging for some dynamat. Trust me, It will make a huge difference.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Be aware that if the back is exposed to the weather, mats, wood hold moisture. When I pulled my matt from the pickup bed, had some bad rust. I will have to paint, scuff and use rhinoliner, bullhide or some such, as they won't trap H2o, and rust.
zippo854
