codfish
Drive a hybrid. I NEED your gas!!
- Jun 9, 2022
- Newfoundland
- gary
- K10
So since I’ve owned this rig I’ve had a slow coolant disappearing act going on. ZERO water in the oil. No visible external leaks. No smell of coolant in the exhaust whatsoever.
Used the ole girl harder this weekend than usual, moving from one cabin to another. “Used” about 3/4 of a gallon of coolant during the 250-300 kilometres in all.
Now I can smell the coolant in the exhaust, and it is clearly on the drivers side. And once the engine is up to temps you can see the extra exhaust from the drivers side.
Intake gasket changed last year for rear oil leak.
Did a compression test today. Here are the results, and a pic of the plugs.
Any suggestions as to where to start? Won’t be right away as I’m off to work in a couple of days for 2 weeks, but might have time tomorrow to check any simple things.
Thanks
Codfish
Thanks
Codfish
