Locating factory height stock spindle
1984C30
castalia,NC
Patrick
c-30
Hello, new to the forum. I have a 1984 C -30. I am looking for a factory height front RH spindle. All I can locate are 3” drop spindles. Lost a wheel bearing and the spindle is damaged. Any help would be greatly appreciated. If this is wrong section please move to correct place. Thank you!
Strick
Dunn, NC
Harold
C20 Crew
I believe I have a set. I'll check the casting to see if it's the same as yours.
Strickland
1984C30
castalia,NC
Patrick
c-30
Wow awesome thank you. I didn’t think they would be so hard to find
Turbo4whl
Downingtown, PA
Wayne
Beautiful truck!
1984C30
castalia,NC
Patrick
c-30
Beautiful truck!
Thank you, I really appreciate it. It’s a daily driver work in progress. Hope to find the spindle I need so I can start using it again soon.
Strick
Dunn, NC
Harold
C20 Crew
I don't have the dually spindle. Only 20 series 2wd. Have some Dana 60 dually tho.
Strickland
Bennyt
Surprise
Ben
I'd call all the local custom shops in your area for used parts. In Phoenix, there are hundreds of lowered C30's so I would think there is a ton of used parts available.
1984C30
castalia,NC
Patrick
c-30
Thank you for the replies, I found 1 30 miles from my house at a junk yard.
1984C30
castalia,NC
Patrick
c-30
Got it back together with the junk yard spindle and new hub/rotor assembly. The spindle was stamped with GM RH6870 it worked though and been driving it around last 2 days. Great to be back in action
Jleopard77
