Getting rid of old gas
Buck69
Northern British Columbia
D30 CUCV
6.2 (removed)
The bulk plants up here take it for a reasonable charge.
Have you tried there?
Finkaire
Finkaire
California
Loren
Silverado c10
Weed killer?
Camar068
10 yrs Air Force
seafoam and lawnmower or weedeater
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Run it in a daily diver a gallon or 2 at a time to dilute it. I've actually let it evaporate before lol
^^^^ This
And I’ll add I’ve mixed it equal parts with diesel oil and used motor oil for starting fires in the shop stove. The old gas gives the mixture just enough kick to light easily while also burning hot and long to get wet firewood going
GTX63
Tennessee
Ty
Yep, the other day I emptied out 5 gallons of unleaded shellack from a rusty gas tank into one of those empty square kitty litter buckets.
It looks like Bourbon. I'll drop engine parts into it for a soak and it will become a parts cleaner.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Either use it for washing greasy parts, or weed killer.
drumvirt
Virginia
Danny
C-30
I run a couple of glurgs mixed fresh gas in my IC engine on my wood splitter. Nary a problem. But anything else is extremely risky folks. Ever heard a child having to get her burnt skin peeled off at the hospital? I have. Hard to even mention it. Don't want to hear of anybody here gettin hurt, or their family, property, or squarebody. Gasoline vapors are 3X heavier than air. Read the quote below from the following site:
Gases and vapors that are heavier than air will flow downhill and gather in pits, against dikes or walls, in swales, and in other low-lying, partially enclosed areas. When they accumulate, they can create hazards. Pay attention to the vapor density of any chemicals in your facility that:
  • Are combustible, flammable, or explosive. When these chemicals flow into low-lying areas, they can collect in sufficient concentrations to form a combustible, flammable, or explosive mixture. They can also travel along the ground to a source of ignition and “flash back” to where they originated.
Rebus
WA
Scott
Run it in a daily diver a gallon or 2 at a time to dilute it...
You can get away with that easily in a carbureted engine in the summertime but I wouldn't do it with fuel injectors. It can gum them up pretty quickly.
Washington
Ya, and the definition of “old” doesn’t have very succinct parameters…
6-9mo old and just smells like stale fuel, goes in my company truck gas tank, lol.
Looks like “bourbon” and smells like paint thinner like mentioned above = weed killer or toss it on a pile of yard waste and light it off.
ulm4lyf
Trevor
Sierra Grande 15
I always feed it to the multiple fire ant mounds on my property. That'll teach the lil boogers!
Bigbluesquare
