- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
No, a stock 85 gas engine would have had an electric choke. Basically a power wire(20A) runs from an ignition source, through an oil pressure switch that goes into the block at the port right above the oil filter and then straight to the electric choke. When power is not applied to the choke, the spring inside pulls the choke on(just like the thermostatically controlled chokes). When you start the truck, the oil pressure switch closes and lets power flow to the choke. This heats the spring element up and pulls the choke off. The power should be applied to the choke the entire time the engine is running, otherwise the choke will come back on.I could definitely use some help with it. I assume that originally it had a switch in the cab to switch it to on choke or off? I thinking to fixed it i'd need to run a wire through the fire was to a switch, and then a second one back to the carb? I don't know where would be the right place to get the power from
