- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Hey, can someone help me out here? I've just now learned how to load photos but I still don't know how to do it right. Why does it have the photo in regular size but when I post the thread it loads a larger version of the same photo. I don't understand what is going on and don't have enough computer knowledge to know how to do much.
Also, how do I continue the text under a photo. It's not letting me continue the text under a photo and move on with my story to a point wher another photo would be inserted. How do I do that? Is the direction in one of those icons in this tool bar above? Or what?
OK so since you're using the forum to host your pics, which is totally fine, the way the forum software works, you can't text under a pic during your first post. BUT HERE'S THE HACK. So after you post the pics. Then go to EDIT which you can only do for like 48 hours or so. Then scroll the bottom of your post where you see ATTACH 12456 ATTACH etc, each ATTATCH is your pic, so now you can type in between the ATTACH or under the ATTACH and it will then put your text under the pic.
