Square Body owner new to Forum
ian s
Oxford nc
Ian
6.2l
Hello everyone I am 18 and have been slowly wrenching on my square for about 2 years now. It is a 1986 k10 with a 6.2l J code diesel. As of right now I am running 35s with 3.08 gear ratio naturally aspirated. As I am sure many of you know its not a great combination for highway use. I have a 700r4 tranny so i am looking to swap the rear axel to a 14bolt ff with a 4.10 gear ratio and change the 10bolt upfront to match the gear ratio and lug pattern of the rear. I have purchased a banks turbo for it as well to pep the motor up. If anyone has a 14 bolt for sale with a 4.10 ratio or any advice on this swap all input would be greatly appreciated.
animal
Lee
c10 silverado
350ish
:welcome:
WFO
Texas Panhandle
RoryH19
Rory
R10 Silverado SWB
Welcome from TX.
Nice truck.
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
FireTruck1984
Michigan
1984 and 1984
Welcome from the Motor City Ian, that’s a good lookin’ ‘86
It’s great to see guys your age keeping the hobby alive !
1973c10
Don
Welcome from Oregon
Shorty81
Baby Boomer
North West ohio
Darren
Welcome from the Buckeye State. Nice Chevrolet.
Welcome from NE Georgia
TubeTruck
East TN
Denis
Suburban K10
LQ9
:welcome: from northern IL!
Swap is pretty straight forward. You'll need bigger u-bolts for the rear and the top plate for the 3/4 ton axle, the rear u-joint is going to be bigger. The front should just bolt right up and should be the same u-joint, just make sure you use new u-bolts. 8 lug wheels and you're good to go!
roundhouse
atlanta ga
justin
77,78,79,80 ?
When you find an axle , pull the cover and inspect the gears for wear, and verify the ratio.
Ask the seller if they have already removed the cover to inspect, if they have not, and don’t want you to,
then they don’t know what the ratio is , or they don’t want you to see how bad the gears are worn out
Some people either don’t know the ratio or they lie about it since 4.10& 4.56 are worth more money than 3.08 and 3.73
Every one will just claim their axles are 4.10
TJinAZ
