77 K10 LS Swap
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
May just be a shoe soaking up moisture and swelling? My 87 celebrity used to do that on the pass side rear wheel when it was wet out. Hit the brakes and that wheel would lock and squeal the tire. Idk why...
Funny that you chimed in with this. I worked at a big multi franchise dealer in the 80s. All the A bodies did that for as long as that body style lasted. You could reduce the symptom by baking the shoes a bit. A few consecutive stops from 60 MPH using only the parking brake would usually suffice.
Joe
78C10BigTen
pennsylvannia
C10 BIG TEN
Joe
I used to have fun with it lol ****** with the guy behind me id wait till he was tail gating me then stab the pedal and lock up that wheel and watch him turn white!
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Starting on building a catch can.
rpcraft
Robert
LS 6.0 364 CID
Nice start. I'm kind of eyeing a mini lathe now days for similar projects. I know that is a slipper slope becomes next after that I'll be looking for an end mil, lol.
Madhorn
AR-Arkansas
Ken
Almost ready for final assembly and install.
Madhorn
AR-Arkansas
Ken
Yes a lathe and mil would be awesome.
Madhorn
AR-Arkansas
Ken
Installed catch can today. Trucks ran well during shake down run.
Camar068
10 yrs Air Force
nice work. Always good to have one on these engines to keep the intake clean amongst other things lol
Madhorn
AR-Arkansas
Ken
Thanks. This is the second one I have put together. I also run an RX can in my wife’s 15 Yukon. The DI engines need a can more than the earlier ones.
Madhorn
AR-Arkansas
Ken
Had some time to kill this weekend and decided the 77 needed day time driving lights. At first I was going to install a set of LED lights out on the brush guard. The more I thought about it I didn’t want to add another set lights so I decided to wire up the low beams on a relay. Now the low beams are on a key on relay. So far good.
78C10BigTen
pennsylvannia
C10 BIG TEN
Cool look. Id add a medium size led bar to the bottom beam of the push bar where the mouting tabs stick up. Do those lights come on with the lows?
Madhorn
AR-Arkansas
Ken
The flood lights actually come on with the high beams but can turn the off with a switch. A light bar may be in the near future.
78C10BigTen
pennsylvannia
C10 BIG TEN
Awesome setup. Did you customize that push bar too fit?
Madhorn
AR-Arkansas
Ken
yes. It is actually for a latter square but I made it fit. Even cut the bumper in to 3 pieces and welded it all to the brush guard.
referrich
