Rusty Nail
- Jan 29, 2015
- the other side of the internet
- Rusty
- C20
- 350sbc
Lol ...
Got fed up an Went through replaced a few vac lines and clamped or cut the ends off the rest now I'm pulling 18" without touching the timing that's a next weekend thing. It's running fine the only thing I notice is it misfired on 2 corners I took during hard acceleration. Once again thank you for the input from everyone especially 87 I know your studying for finals I really appreciate you taking time out to help a rookie.
Lol fair enough rusty no hard feelings
Just making sure the credit goes where's it's due
Does high altitude have an effect on engine vacuum???
Yes. That's because engine vacuum is relative to atmospheric pressure. So, the lower the atmospheric pressure, the smaller the difference between that and engine vacuum. Engine vacuum decreases about 1" hg for every 1,000 ft above sea level. So, a 350 that makes 20" hg in Houston would make around 15" hg in Denver and only 10" in Breckenridge!Does high altitude have an effect on engine vacuum???
I also switched vacuum advance cans from a 20 degree can to a 15 degree can to bring the cruise advance down a little.
