- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Technically only a diesel can run without a battery, gas engines do need the spark. But yes, to start a gas engine, a manual tranny can be used to started it with a push and a pop of the clutchBattery is only needed if she's an automatic, pop start that b*tch and let it roll.......
But anyways good to be back and see things are the same here. Did some stuff to the truck only to get it inspected for another year. Found a header blew a hole clean through it on the passengers side. Chased that leak for a few days thinking it was the collector gasket, then the header gasket at the head but nope ugh. Got a new set of headers ordered through Summit, will get em on here in a week or so when I go on call so the truck has some down time. Found one of the supporting crossmembers in the rear of the frame broke and another is completely missing, again dealing with the demons of the PO and fixing things they did. Got the oem grille back in it, thinking of going with a two tone scheme with it to match the body colors, pics to come later when/if it gets done. But yeah, it's good to be back lurking on the forums
