Taillight question
DatKat933
Law Enforcement
WA
Anthony
SBC 350
Hi everyone, I apologize if this is posted in the wrong spot. I had a couple of questions about the taillights on my 79 K10. I am prepping it to be driven more after sitting for several years. The taillight were out since I had to replace the bed on the truck. Since then the bolts and screws for the taillights have gone missing. Does anyone know what size screws it takes to secure the housing to the bed and the lense to the inner housing? Also, are there clips that need to be ordered to secure the housing of the taillight to the bed itself? The holes in the bed are larger than the screw holes on the taillight housings.
Secondary question, is it normal to have alignment issues when installing taillights back into a new bed? The taillights do not sit flush like I remember them doing on the original bed of the truck. Instead they leave a pretty noticeable gap when I put them in place.
Thank you!
I don't have my screws handy but the backing plates are LH/RH specific. If you get them mixed up, the lights will protrude more than they should.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Been a minute since i replaced the housings on mine but
The inner housing uses these screw clips to attach to the truck. The exterior housing (the nice looking part) screws into holes on the inner housing.
And yeah they should be marked LH RH
Moderator
Going off memory...
All taillight screws are #8 sheet metal screws. The ones in the housing are phillips head. The ones for the lens are panhead torx, in stainless. Older trucks are maybe phillips there too, and stainless. 3/4" or 1" long.
DatKat933
Law Enforcement
WA
Anthony
SBC 350
Perfect thank you!!
DatKat933
Law Enforcement
WA
Anthony
SBC 350
This is the alignment issue I was talking about. I am still getting the screws and clips together to actually secure them, but they seem to have this rather large gap between the lense and the body. The housing is pushed all the way into the taillight socket and the lense is pushed against the housing.
neiltee
San Marcos, CA
Neil
LS6
Thank you!
I think you should be able to order the specific ones at LMC.
Moderator
Got a picture of your taillight opening, without the lense and housing in it?
Every time I've had that happen, it's cuz I had the LH and RH backing plates swapped. Check to make sure you have the correct backing plates on each side, they should be labeled LH or RH
DatKat933
Law Enforcement
WA
Anthony
SBC 350
I double and triple checked that because I thought that was the issue and they were on the correct side. Im hoping to try to bolt them up in the next week or two to see if securing them to the bed will help suck them in any.
Moderator
Very stupid question:
Are you maybe installing the housings upside down?
I'm not trying to insult your intelligence, I just thought there's a small chance it might be worth asking.
DatKat933
Law Enforcement
WA
Anthony
SBC 350
Haha I know you're not. I don't think they were but I will try it none the less the next time I work on the truck just to make sure. And if that is the issue then no one will ever know and I will disappear into the background. Haha
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
If that's the case, let us know. Don't run away!
So we can
1) have a chuckle over it
2) remember not to do it too
3) inevitably something else will come up and you will be back. It's the natural way of things.
DatKat933
Law Enforcement
WA
Anthony
SBC 350
So we can
Oh ya, I'd be back haha. Over the years I don't know I would have survived this entire project without this forum.
DatKat933
Law Enforcement
WA
Anthony
SBC 350
It might be a dumb question, but LH is left hand/drivers side right? I tried it on the passenger side and it looked way off. This is how it fits on my driver's side. It is possible it is a fit and finish issue with the bed side. I bought a bed and the new replacement bed side came with it. So it may just be an issue with where the bed side came from.
hauto85
