Random Engine Bay - Vacuum hose and empty electrical clip
wccasey75
pooler, GA
William
I can't seem to find where this vacuum line attaches (image 1), or what is supposed to clip in to this orange connector near the brake booster (image 2)
Image 1
Image 2
Gpaw44
Alex
That hose goes to a T at the bottom of the carb on drivers side. Note arrow C. It Ts off the EGR port.
Jgonick
West Texas
Joel
orange is a test port for transmission.
Vacuum hose is from the TIP IN vac switch for Electronic Spark Control.- i believe it takes full manifold vacuum. it is for ESC to adjust distributor (depending if the distributor was changed - it might not be needed)
jw23655
