rough running....backfiring 350
Ken B
indiana
ken
if the vacuum line to the distributor wasnt in place when/if the timing was set wouldnt it be incorrect?
I am trying to grasp the sequencing of what happened.
Sad Sack
Nebraska
Goober
C15
Too lazy to read the past comments but did you put new spark plugs in or just wires?
Ken B
indiana
ken
plugs and wires were replaced.
Sad Sack
Nebraska
Goober
C15
How did the plugs look?
Soot saturated?
Oil saturated?
Clean?
Tan?
Just plain nasty?
Ken B
indiana
ken
Same plug just different angles...just pulled it .
You are supposed to time them with the hose removed and plugged.
Ken B
indiana
ken
Thank you.
Ken B
indiana
ken
Anyone have the experience to look at that plug and tell me what you think is going on ?
Ken B
indiana
ken
so i think I have the "plumbing" corrected. Now I need to check timing.
guess a Harbor Freight light is in my future
Ken B
indiana
ken
So I had a thought, the circled area has a new plate on it, the smog stuff was removed and this plate was installed. Could this, if not sealing correctly be an issue?
Moderator
That's an egr block-off plate. As long as there is actually a gasket under it, it's "probably" fine. It'd be really hard to botch that install.
Ken B
indiana
ken
can i test the gasket with carb cleaner and see if it is leaking?
WFO
Texas Panhandle
Have you checked your distributor cap and rotor?
Sad Sack
Nebraska
Goober
C15
^^^^^ what he said^^^^ or like I posted earlier, try another ICM.
jw23655
