Socket organizer need help for homemade
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
I want to make a socket organizer similiar to the ones in the picture. Ready made us not going to be an option. Things that come to mind is hopefully someone knows of some polyurethane or similar 1 can pour around the arranged sockets. Some kind of dense foam I can cut. Or some guidance on how to make them with a 3d printer. Or ???? Thank you
This is what I'm using for my tool box
legopnuematic
Licensed Junk Dealer
MO
Spencer
I figured as such.
A cheap idea is try expanding foam sprayed into a grocery bag, pressing the sockets into the bag, like how they do it with shipping. Not sure it would deliver the durability or ‘resolution’ desired.
I did my road box with FastCap Kaizen foam some years ago and am pleased. I cut rectangles and laid the sockets on their sides however, not standing up.
Pourable silicone might work (for mold making). Pretty minimal shrink factor if I am not mistaken.
Or…
Sad Sack
Nebraska
Goober
C15
IDK, I know nothing about casting resin,that's why I asked in my original post does some body know of something I can pour around the sockets. Do any of you know about casting resin?
Apply mold release to sockets, arrange in your form, mix resin really-really well, pour to the depth you want and wait for it to set. Hardest part I imagine will be devising a way to keep the sockets from moving around when you pour it into your form. Stuff is really easy to work with.
Sad Sack
Nebraska
Goober
C15
Another form of resin is also Googled using the search parameter of “ bar top resin”, like when ya throw down coasters or bottle caps then cover them with a clear base to make a a table or bar top covering. Friend of mine did this for his bar, looked killer.
hoagster
California
K10, 1500
5.3l
I'll have to give that a try with the foam sheets that I posted earlier in this thread.
Finkaire
Finkaire
California
Loren
Silverado c10
Great idea! Now comes the wrench organization.“organization” key to efficiency!
hoagster
California
K10, 1500
5.3l
That is cool and it worked on the foam I bought from Onreva. What is nice my deep sockets can now standup in the drawer. With other socket holders they sit up to high.
Dejure
Eastern Washington
Kelly
C15
(1) I used to by epoxy by the five gallon bucket (five part A, five part B). Even by the five, it was expensive.
Add to the forgoing, most epoxies are formulated for relatively thin pours of about 1/8". More than that and you'll see smoke rolling off the pour. Formulas that tolerate thicker pours are going to be the higher priced ones.
To pour around a socket would be doable, but tough. Though epoxy is thicker than poly, water and so on, it'll still seep at every opportunity. The bottoms of each socket would have to be well sealed. Then you'd have to deal with the resin locking into what you used to seal the bottoms.
Finally, there is that you'd have to wrap each socket in something the epoxy didn't want to become close friends with.
(2) Now that I have a printer, I can say you might be best served going down that road.
One thing I've learned in the short time of using my printer is, planning lettering to limit how many times the printer has to swap filaments [if you don't have a nice unit with two or more hotends]. For that reason, When I can and the aesthetics allow, use lettering and numbering as an add on, so the machine only has to switch once. That vastly speeds up production.
As an example, one of the nice looking ones showed socket sizes on the angled side, so once the print hit the lettering, it would have to swap filaments on every pass, until the lettering was complete.
The nice thing about many of the ones available is, with some fiddling, some can be enlarged or reduced without affecting holes sizes
If you found a method other than 3-D prints, you could still have numbers printed and attach them to whatever method you resorted to.
(3) Long ago, and because I can, I figured out many of the things I want can be made from wood or other material workable with standard woodworking tools (saws, router. . . ).
Once sealed, heavy density fiber board can be sprayed with automotive paint and will look like the fender of that nicely painted hupmobile.
(4) Other materials workable with woodworking tools include Corian type products and plexi products, the latter which can be welded together to make thicker pieces using certain solvents and weights.
(5) On workable materials, you might be able to drill oversized holes in specific ranges, then install inserts that take up the slack in each. That could be tubes or the equivalent of cut to size match sticks (say one vertical every 120-degrees or less).
Finally, you are going to make at least five socket holes for 10mm, right?
Dejure
Eastern Washington
Kelly
C15
I pulled a bunch of things out of my tool box and played my hand at (George Jetson button pushing) printing.
WyldTinker
