Truck82
- Nov 2, 2024
- Alderton
- Christopher
- c20
Comp Cams says these rocker arms are supposed to be used with guide plates… no big deal, I’ve already drilled and tapped for screw in studs I would just need the guide plates and correct studs. But I’ve read you don’t need them if the hole in the head (where the pushrod goes through) is the smaller size. Is this correct and if so, do my heads have the “smaller” hole? They are Vortec heads so does that only apply to the older heads? Any help, information, and experience is appreciated. Thanks guys
