3/4 ton GMT400 Burb & ORD SAS and 6BT Swap
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Did some research and looks like °150-°170 for around 1 1/2 hours in the oven.
Watched this video. Made me laugh a little but had the information I was looking for at the end.
squaredeal91
Greg bush
1991 SB
Got both front mounts on and drilled 3 holes for each side, pretty easy. Each bracket uses 9 bolts to mount it. (4) 7/16"bolts and (5) 1/2" bolts.
The rears have to be measured and then set and all of those holes have to be drilled out im pretty sure.
mo4154
