Transmission Fluid Question
VPC20HD
California
Vincent
C20 HD
Hello,
I have an 82' C20 that has the TH400 3-speed auto.
I added a quart of Dexron 4 and after, I realized my truck needs Dexron 2.
Is Dexron 4 acceptable or do I need to do a complete transmission fluid change to Dexron 2?
Edelbrock
Earth
Grumba
K5 Blazer
You can always go up in number with the Dexron without any problem, you're good to go with what you did.
Agreed. From my understanding, you can always go up on the Dexron number, but never down below the minimum number. The higher numbers are just better versions of the lower numbers and are backwards comparable.
Do not follow the logic that higher numbers are good,on any lubricant without double checking. A good example is GL5 80/90 gear oil,it destroys brass synchros in people's transmissions all the time people assume they can replace gl4 with gl5.
VPC20HD
California
Vincent
C20 HD
I actually put Dexron 6. Got the Romain numerals mixed up. What I’ve been reading is that GM stated Dexron 6 is a replacement for Dexron 2. Can someone confirm this or had experience switching from 2 to 6? I’ve also read Dexron 2 is obsolete now and no one really makes it anymore.
fast 99
Spokane, Washington
As far as I know Dex 6 is just a higher quality synthetic version and can be interchanged with dex 1,2 or 3. Usually don't use it as a replacement for the older versions because of higher cost. Oil is expensive enough.
NickTransmissions
Las Vegas
Nick
what's Dexron 4?
Use DexMerc, Dex6 or Ford Type F
All prev versions of Dex apart from DexMec and Dex6 are obsolete and out of production, AFAIK.
VPC20HD
California
Vincent
C20 HD
what's Dexron 4?
I meant to say Dexron 6.
Ok, I feel more at ease now knowing Dexron 6 will work as a replacement for Dexron 2.
gsuburban
L.A.
G
V1500
Having a loss of a quart of transmission fluid suggests the best practice is to find why its a quart low. It also would be good to know when the last fluid and filter change was as that would suggest if adding a quart or going with a complete fluid and filter change to be the best idea and all the same version of fluid. A transmission rebuilder shop, an independent, would likely be the best approach to find why fluid is low. Trans fluid changes are best every 30,000 to 40,000 miles. Also, I wouldn't be mixing fluid types, regardless of "its compatible" with the transmission.
BadBowtie
North Texas
Jon
Chevrolet
5.0L
..... I would have added a bottle of Lucas Transmission Conditioner if she was a quart low. Good stuff.
xm20k
Girard, Ohio
Crap I'm the weird one.
I use Mobil Delvac tractor fluid with a splash of type F for taste. I mean color so I can see it on the stick.
Powerglide race trans.
Tahner45
