Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
I had the 6.2 pump with hydro on my 327. I went serpentine in my new setup. I got a ps pump from a 96 c3500 I think. It has dual return inlets and a single out just like the original cucv pump.Okay so I’m caught up on the powersteering/hydro boost. So I cannot use the pump from the 6.2? How do I hook up the lines if I buy a different pump cause they don’t look the same at all...
What’s the holdup with using the 6.2 ps pump on your setup?
As far as the pipe routing...iirc it the pressure outlet on the pump goes to the hydro boost, from the HB to the steering box. They both have dedicated returns to the reservoir.
