WONT START
San Angelo
Steven
sierra classic 1500
Having an issue starting my 87 GMC sierra classic it started this morning then immediately turned of it try to crank but won't start where should start troubleshooting has a new fuel pump hadn't listen for to come on yet but don't think thats it
73c20jim
Tombstone, AZ
Punctuation is your friend. Not a grammar ****, but it makes it much easier to read.
San Angelo
Steven
sierra classic 1500
I sprayed starter fluid in the TBI. Started the rest of the day no problem kinda confused on what is going on.
San Angelo
Steven
sierra classic 1500
It seems my a/c works ok just doesn't blow hard. Can I use a newer model blower? I Believe I located the blower against the firewall on the passenger side. Is this correct?
Dave 84
Arizona, glendale
Dave
Yes you are correct but did your no start get corrected?
Rusty Nail
Rusty
350sbc
Yes.
They slow down in time. A new replacement will work much better than your current thirty year old one.
Hope this helps!
4WDKC
Southern Florida
Kacy
check fuel pressure, just casue its new doesnt mean its good or makes the right amount of pressure..those tbi pumps were notorious about not being consistent.
Rusty Nail
Rusty
350sbc
I only assume that "hi speed" works okay? It's really easy to lose high speed blower in square trucks but luckily, it's also really easy to fix!
San Angelo
Steven
sierra classic 1500
Also my vapor canister is getting fuel in and leaking. What are common issues that i can check to fix this issue. Where is my purge vavle located is it the one in the crank case?
wilson79
