Won't fire...HELP!
fallguy
Minot, ND
Jamie
Silverado K10
350 Edelbrock carb.
Ran all day today just fine. On and off several times. About an hour after last star...it just rolls over...no fire.
Put some gas in carb....played with choke flaps manually...suddenly started and ran good for 4 minutes...then suddenly died. Tried to start and tried same screwing around but with no luck.
It did this weeks ago, started to smell gas. Waited about 15min and it started with no issues like that again got weeks.
New motor, new fuel pump, new everything about 15k ago.
WTH!?! Help!
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
check all your fuel lines where the rubber lines are you might have a cracked line causing it to loose suction or a bad fuel pump
dmcelhan
