Wireing help please
james27
Idaho
James
I have two wires that I don't know where they go. I took pics before disassembly but lost all of them. I'm missing the batt wire that hooks to the distributor so maybe one on these go there. The one with the boot i have no clue about. Its not the oil pressure i have that see pic 3
fast 99
Spokane, Washington
What is the base truck? Appears to be a Vortec small block with an HEI dist? If I was guessing one is power supply for electric choke [oil pressure looking plug] other could be 12V to dist.
SirRobyn0
I was thinking the one in his hand is oil pressure the other is HEI power, but he says the oil pressure gauge is hooked up. Base info on the truck would be helpful. Maybe a picture zoomed out a little more might help. Does the truck have a factory tach?
newguy11
New England
Private
C/k 10
Remember that these trucks ( generally ) have an oil pressure sender and an oil pressure switch. The one wire with a black boot is the oil pressure switch it connects to the intake behind the distributor. The other wire I’m prettier sure is the to the choke
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
The fat white plug screams distributor power, the other to one of the oil pressure switches. Wire color compared to the wiring diagram should confirm which is which. What exactly are you working on?
I' d bet new guy is right. He has the op sender hooked up for the gauge but on anything carbureated its going to need on op switch for the choke also.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
White wire goes in the dist, right side of cap, in the front I believe. There is a slot for Tach there too.
jbwhitford
