Wiper issues
aGood'olBoy
Waterford Pennsylvania
Jeremiah
Well on the way to work yesterday in typical pa fashion it started down pouring. I had my wipers going fine till things started to go funny. The wipers were going fine till about 2/3rds up of its upward stroke and at the same spot on its downward stroke. It would drag like its bogging down. It did this for a little bit till it just stopped in that position. So I drove to work with the wipers stuck like that. When I got out of my truck I grabbed the wiper and gently pushed it down. It didn't feel like it was binding on anything and was not difficult to put it back to its resting spot. This isn't the first time this happened. I'm not really sure what the root of this problem is. As always and help and input is appreciated
bigcountryguy19
Sealy texas
josh
6.2 diesel
Most likely the wiper motor gearbox.
datto62073
Monroe
Mark
Just one. There is a linkage in there that ties the two arms together.
The wiper motor has three brushes; the "common" the low speed, and the high speed. When the ignition switch is "ON," power is applied to the common brush. The low speed and high speed brushes are connected to their respective ground via the control switch. When the control switch is positioned at "HI" or "LO" speed, a ground path is connected to the high or low speed brush in the motor. The motor runs at the switch selected speed.
I would suspect that (if the motor is original) it is just that your brushes have worn out and are barely making contact. When the wiper blades are in the mid-swipe part of their sweep arc they are putting the greatest load on the motor.
Most folks don't feel like breaking open the wiper motor casing, sourcing new brushes, soldering the pigtails in and then re-assembling everything. Not when a reman motor is less than $50 and a JY unit is about $15.
I would check/change the motor before tearing into the linkage. The motor can be changed without pulling the cowling, arms, etc.
Just release the three mounting screws, and gently pull the motor away from the firewall. There is sufficient flex in the wiper linkage to do this. You will see a crankarm with a ball on it that connects to the linkage - leave that (ball joint) connection alone.
The other end of the arm is secured to the motor shaft with a nut. That nut can be released (and the crank pulled off the shaft) by inserting a wrench between the firewall and the wiper motor frame and onto the nut. That is how I disco the arm from the shaft.
But the textbook way is to use the hole provided to release the nut. It is offset quite a bit from the connection. That makes it hard enough. But also, more often than not, I drop the nut down into the depths of the plenum and have to spend a couple of hours fishing it out.
When you go to reassemble the crank on the motor shaft be SURE that they are indexed to each other correctly. By that I mean, it is important that both the motor and wiper arms are in the fully parked position.
The crank arm can go on the shaft in 2 different positions. If the arm is 180 degrees off from the normal angle, it will suck.
The first time you operate the wipers, the blades/wiper arms will work beautifully - except for the fact that they will park at the top of the windshield. You will have to do the job again.
The wiper arms are easy - just push them down to a point where the blades are almost touching the windshield gasket.
To preset the motor to park position, just plug in the wiring harness connections, turn the switch on and run it for a couple of revolutions. Turn the wiper motor off at the switch and then mate the motor shaft to the crank arm.
It might sound wicked involved, but everything will become obvious as you do the replacement. Here are a couple of pictures to help explain - I can't type any more:
highdesertrange
kalifornia
mike
k30
good write up chengny with pics too. highdesertranger
Yeah, thanks - I hate typing but I had to speak up when I saw his responses below, I figured he could use a little guidance:
Hmmmm so I guess I need a pair of wiper motors.. Thanks for your help
Makes sense. Just pop the cowl off and r&r it, correct?
We Jeremiah's have to stick up for each other - all those bullfrog jokes and crap.
aGood'olBoy
Jeremiah
Hahaha the bullfrog jokes do get old.
That was a great write up too. I appreciate it more than you know!! Hopefully it won't rain too much before I can scrape up the money for a new motor.
Get you some RainX for your windshield for just in case it does rain.
My idiot redneck hillbilly dad has problems with his 94 and the wipers working right. I've told him 100X it's a common problem on 94's only and what to replace to fix it but he won't. I told him about RainX to get by til we got them fixed about 6 years ago. I ask him all the time, ever get them wipers fixed?? Nope, don't need no damn wipers, I RainX the windshield twice a year and I don't need wipers. :grd:
aGood'olBoy
Jeremiah
Haha there's a saying about stuff like that.
If its a stupid idea but it works it ain't stupid!
I'll have to get some because I need to do my rear brakes before I can replace the wiper motor.
