Wiper fluid/wiper problem
nmac97
Prince George, BC, Canada
Nick
silverado c10 half-ton
Just bought another square body (an 85). Having some issues with the wipers and wiper fluid not pumping. Wipers only work on low and high setting. They are a bit slow and shudder across the window when turned on. As for when I press the switch to spray fluid, no fluid comes out and the wipers do no move either. Was thinking I might need to replace the entire turn signal switch and the wiper motor. Any help trying to trouble shoot this issue is greatly appreciated. Thanks!
datto62073
Monroe
Mark
does sound like a switch to me. but there again it could be a wiring issue. check the wiring first. a little multi meter time will shed some light on whats going on.
mrtc
