Will Rims from a Current 3/4t fit a SquareBody?
97350
Canada
Duane
C1500
I have seen some 3/4 t 2wd with rims from a 2004 and it definitely looks like the offset is different.What newer factory wheels will fit a squarebody K35? I like the look of some of the newer wheels and would like to know what my options are.
As far as bolt pattern the 11+'s are different but everything previous is the same. As far as backspace I can't answer to that exactly
CSFJ
I thought the offset, or backspace on the newer trucks was similar to a front wheel drive would have.
I was under the impression the new bolt pattern was simply the metric equivalent of the old bolt pattern, making them basically the same. If not exactly the same. I don't know the new specs though.
ceyman72
