Powerhouse Ranch
3G Connoisseur
- Jan 6, 2021
- PA
- Luke
- '80, '86, '88
- C25, K5, V15
Getting pretty cranky with this motor right now, getting me cranky with the truck. Been a problem for a while now, only getting worse. I am young, and I need the gurus!
As we all know, the '88 Jimmy (project thread linked below) has been absolutely butchered by the PO, and i'm trying to piece it all together again. When i got it, it didn't run or even start for that matter.
WHAT I'VE DONE:
-Repaired pinched ignition wire, started the truck
-Oil change
-Made sure all motor wiring was plugged in, vacuum lines where they need to be, etc.
-Replaced aftermarket fan with an original from Burb
-Replaced radiator, flushed system
-Replaced oil sender
-Replaced all spark plugs (they were very rough, can take a picture later if necessary)
-Played with timing, not 100% yet
-Running new fuel, with small amount of Berryman's to help clean the fuel lines that sat for years
I believe that's it. . . THE MAIN PROBLEM, whether this is related or not or simply having to do with the throttle, when i'm giving it gas, there's nothing, there's nothing, then all the sudden there's everything! I looked at the throttle cable linkage and all that jazz and compared to Burb and it looked the same, not too knowledgable in this category yet. I need this throttle pedal to be a normal throttle pedal and i need the engine to idle like the happy little small block that it is. If i need to do a video of it running or the throttle thing i'm explaining, just ask. I need to figure this out!
Any tips and tricks are highly appreciated
WHAT I'VE DONE:
-Oil change
